Old 04-26-2016, 01:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
LS4 Transmission Problem Thread (4T65-HD); Current Total Inside
Old 01-08-2011, 09:15 AM
  #81
98GTcoupe's Avatar
Dont forget me!
Mine when its cold does the Reverse to D clunk. and overdrive slipping when cold. Or just slipping in any gear "sometimes" (dealer cannot replicate) lol. So, yeah add me. Im sure ill be in the blown/replaced list soon..
Old 01-08-2011, 01:04 PM
  #82
LS1 Racing's Avatar
Originally Posted by 98GTcoupe
Dont forget me!
Added you!
Old 01-11-2011, 04:02 PM
  #83
LS1 Racing's Avatar
Added Ran-Dom32 to the trans failure list. We're up to 99 users with current or past transmission problems.
Old 01-12-2011, 12:49 AM
  #84
blakss's Avatar
actually just checked and im not on there. so if you could add me to the list. gave out at 67k been rebuilt about 12 months now
Old 01-12-2011, 11:56 AM
  #85
LS1 Racing's Avatar
Added you...You're lucky #100!
Old 01-13-2011, 07:29 AM
  #86
vroom_vroom's Avatar
Might as well tag on my broham dewd87 he had his replaced
Old 01-13-2011, 03:27 PM
  #87
LS1 Racing's Avatar
Added dewd87 to the list and updated the total.
Old 01-13-2011, 08:25 PM
  #88
why_so_serious's Avatar
you can also go ahead and add me for the original tranny slipping
Old 01-13-2011, 08:53 PM
  #89
07MCSS's Avatar
Originally Posted by 07MCSS
Add me to the second list. Mine is making noises and it's throwing codes. I'm taking it in next week.
Ok, take me off the list. Noises were not tranny related according to the dealer. They even applauded my efforts with the turbo setup. They are a dealer for Mast Motorsports engines and will install one in just about anything so they have some understanding about performance mods. The culprit is my down pipe rubbing against the firewall and the codes were from a tire pressure sensor. It never had any shifting issues. I guess it was just my paranoia. I don't dog the car. It is my only transportation. I am runnning 10.5 psi with the turbo setup now which should have me well above the 400 fwhp mark with no other issues. Yipppppeeee!
Old 01-13-2011, 11:01 PM
  #90
LS1 Racing's Avatar
Added you to the list.
That's great news!
I removed you from the list.
Old 01-13-2011, 11:22 PM
  #91
blakss's Avatar
lucky me!
Old 01-16-2011, 11:54 PM
  #92
sohcgt96's Avatar
*Knock on wood and crossing my fingers it stays this way*
No problems yet, purchased the car on 11/10/2010 with 52,000 miles on it. Had the trans get up to the 190 range on the couple of 70 degree days we were lucky to have in november, never gets above 140-160 right now but its winter. Only driven just over 2K in that time, everything seems cool as far as I can tell. I wonder if the previous owner got pissed off and traded it in after a trans failure and rebuild? It seems a lot of people don't make it far beyond the 60K mark from what I've read. If so, that'd be fantastic for me, but I have no way of knowing really.
Definitely plan on doing a cooler in the spring and I saw somebody makes a deep, finned trans pan with a drain plug. It was kind of expensive but I don't mind if it prolongs the life of a part of the car it is VERY inconvenient to do major service on.
I've got 2 years and 24K of aftermarket warranty on the car so if something happens, hope its during that time.
Old 01-17-2011, 12:14 AM
  #93
LS1 Racing's Avatar
@sohc96, thanks for posting your experience.
Hopefully, you'll be one of the lucky ones.
One way to know if you have a factory remanufactured trans is there will most likely be a sticker or ink stamp on the casing that says "Inspected." There's probably no way of knowing if you have a non-factory unit or rebuild.
I do recommend a cooler, however, heat is not the primary trans killer in our application, but rather a design and engineering flaw.
For more details, you may want to do a search for my "Transmission Upgrade Thread."
Old 01-17-2011, 02:41 PM
  #94
Ran-Dom32's Avatar
got mine back today (3rd trans in my GXP) 1700 dollars later , trans temp runs @ 178 is that normal? I have a 1 year warranty, & that's longer then I plan to keep the car, I'm going to drive it like I stole it
Old 01-17-2011, 07:42 PM
  #95
JC05GXP's Avatar
178 sounds about right
Old 01-17-2011, 08:54 PM
  #96
LS1 Racing's Avatar
Under what conditions did you see 178? Was that the highest temp you saw? What was the outside temperature? Was this primarily city or highway driving? Any long up-hill or down-hill grades? How long where you out driving before you saw that temp? Do you have a trans cooler?
Sorry for the interrogation, but knowing that stuff will give us a good indication of whether that's a normal temp or not.
Old 01-18-2011, 09:39 AM
  #97
Ran-Dom32's Avatar
The outside temp was around 32, normal driving conditions, I did let it idle in my driveway for quite a while & it went up to 195
Old 01-18-2011, 10:46 AM
  #98
LS1 Racing's Avatar
Old 01-18-2011, 10:59 AM
  #99
Ran-Dom32's Avatar
no, I inquired about adding a cooler, but the tranny guy said is was useless, he's the one warrenting the tranny
Old 01-18-2011, 11:04 AM
  #100
LS1 Racing's Avatar
I disagree with him on the cooler. It may not solve our common problems but low trans temperatures are better than higher ones, 100 times out of 100!
I don't think the temps you're seeing are abnormal, considering the driving condtions and outside temp. I would definitely get a cooler on it. You'll see your average temps drop by about 10 degrees, and you might see a lower max of half that.
Quick Reply: LS4 Transmission Problem Thread (4T65-HD); Current Total Inside
