Tire Pressure Monitors
Old 01-20-2011, 08:09 PM
BackNBlackSS's Avatar
Default Tire Pressure Monitors
Anyone here have aftermarket rims? Any issues reusing the original tire pressure monitor sensors over or did you have to buy new?
Old 01-20-2011, 08:19 PM
2005gxp's Avatar
u can reuse them but depending on the style of sensor you may have to buy a new stem or rim band. i dunno what style of sensor you have. post a pic.
Old 01-20-2011, 08:28 PM
GXP25's Avatar
They're reusable and should last ten (10) years (battery life).
As long as whomever removes them doesn't break or damage them, they will work fine.
There are different styles, but here is one style and how to remove/reuse them:
Source: 2011 gs tpms location - Corvette Forum
EDIT: Make sure you remember what sensor goes where. If you move the sensor to a different tire location, they will all need to be relearned.
Search this forum for the relearning procedure (I posted it not too long ago).
Old 01-20-2011, 09:18 PM
ReD715's Avatar
When I put the aftermarket wheels on my car, I reused the ones that came with the car. One of them did break from removal so I had to go to the stealer to get a replacement since it was the weekend. Be careful when removing them.
Since you are reusing the factory sensors, pick up the TPMS servicing kits from Napa which are a few bucks a piece. Its cheap insurance down the road in case one of the seals has a leak.
Old 01-20-2011, 10:25 PM
mike690003's Avatar
Bought new ones because I didn't want the hassle of taking out the ones out the stock wheels.
Old 01-21-2011, 06:41 AM
Red06SS's Avatar
The GM part number for the grommets is 25754190 for the metal stem style. 15263240 is the replacement stem section for the sensors that have the rubber stems.
Old 01-21-2011, 10:33 AM
Awesome info thanx all!
Old 01-21-2011, 11:42 AM
RickAKATed10's Avatar
I have new ones in mine and they don't respond for either set of wheels. Yay me!
Old 01-21-2011, 08:42 PM
ImpSS07's Avatar
10yrs?????? I've never heard that! Most I've heard is 4-5 if your lucky. I had 1 die about 6 months ago and now I have another thats starting to act up.
OP- I re-used the factory ones when I switched to my ASA AR1's.
Old 01-21-2011, 08:50 PM
GXP25's Avatar
Yup, right from GM:
Old 01-22-2011, 06:52 PM
impala06ss's Avatar
GM should have used the motion of the tire rotating / starting / stopping to add charge to the battery in the monitor, then it could last the life of the car.
Old 01-22-2011, 07:00 PM
ImpSS07's Avatar
Yup, right from GM:
Thats crazy!!! So why wouldn't the dealerships cover these if GM says they have a 10yr life span??
Quick Reply: Tire Pressure Monitors
