need help fast!!
If you're talking about the one on the core support and don't plan to use the mount anymore you can cut the mount out. I used a hole saw and it worked pretty good.
The best way to save the mount is to use a screwdriver/pry bar and pry it away from the metal bracket enough to squirt some hand soap between it and the rubber all the way around the mount. Then use a prying fashion and work one side of the rubber out of the bracket and the rest will follow. Hand soap is an excellent lubricant for rubber.
LS1Tech Sponsor
I lubed up all 4 sides of it with wd-40, then used a big flat-head screwdriver and just pushed it out in one whole piece...
piece a cake...
piece a cake...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
