5X115 vs 5X114.3
Old 02-27-2011, 03:53 AM
TML529's Avatar
Default 5X115 vs 5X114.3
I finally found a set of Wheels I like but before I make the purchase I have 1 question. Will the 5X114.3 BP work on The GXP?
Old 02-27-2011, 07:15 AM
94ss06gxp's Avatar
ive heard they will fit but there is a chance they will break the wheel studs. i would get 115 just to do it right
Old 02-27-2011, 07:38 AM
2005gxp's Avatar
ive been running 5x114.3wheels on these gm cars with a 115 bolt pattern without any issues for a couple years now.
Old 02-27-2011, 11:04 AM
TML529's Avatar
I tire & wheel guy voiced that concern to me about snapping wheel studs & said I especially should be concerned because of the high torque these cars produce.
Old 02-27-2011, 11:05 AM
LS1>girlfriend's Avatar
5x115 is the factory lug spacing. 114.3 will work but they make break the studs or cause vibrations.
Old 02-27-2011, 07:00 PM
The Guz's Avatar
I use 5x114.3 on my grand prix which is a daily driver. I have even taken a 13 hour trip (each way) and have had no issues or vibrations. I do use hub rings. I have had the wheels for 5 years now and never snapped a stud. As a matter of fact, I snapped a lug when I was using aftermarket 18's with a 5x115 bolt pattern. In my opinion you will be fine with the 114.3 bolt pattern. There are many guys on other grand prix forums using the wheels with no issues, and that includes trips to the track.
Old 02-27-2011, 10:18 PM
DP 08 GXP's Avatar
my old winter rims were 114.3 and i didnt have any issues
Old 02-27-2011, 10:32 PM
RedHotG8's Avatar
I would only use 115 since I don't want studs breaking and possibly have a wheel falling off. Sure you might get away with it, but you don't want to be one of those that has problems. And it does happen quite often with the wrong size wheels. I definitely wouldn't want to have a problem with a wheel when I'm going fast that's for sure.
Old 02-27-2011, 10:38 PM
AlabamaGuy's Avatar
I've heard some bad things about it, also heard that people have zero issues. However, with the way I drive my car, I'm not sure I could afford to shear a couple studs off in the middle of a turn doing 80, trying to fight oversteer.
Old 02-28-2011, 06:01 AM
TML529's Avatar
Thanks for all the input. I think I'll stick with the 115 BP,not worth risking saftey just for aesthetics.
Old 02-28-2011, 07:54 AM
TSS09SS's Avatar
^^ Excellent decision.
Old 02-28-2011, 08:49 AM
94ss06gxp's Avatar
X2 . . would hate to see you on the news. grand prix driver dead because of wrong size bolt pattern. . just not worth it
Old 02-28-2011, 11:49 AM
RickAKATed10's Avatar
I'm on 114.3 with no problems.
Old 02-28-2011, 12:24 PM
RedHotG8's Avatar
Originally Posted by RickAKATed10
I'm on 114.3 with no problems YET.
There I fixed it.
Old 02-28-2011, 12:26 PM
Originally Posted by RedHotG8
There I fixed it.
meh. lol
Old 03-01-2011, 12:15 PM
Sadden's Avatar
You can do it but you have to use floating lug nuts.
Old 03-01-2011, 04:29 PM
TML529's Avatar
Floating Lug Nutz??????
Old 03-01-2011, 04:35 PM
RedHotG8's Avatar
I think he means the ones that have slotted washers under the lugnuts. They were popular years ago but I don't think they sell them anymore.
Old 03-01-2011, 05:05 PM
Floating lug nuts have a "free moving" washer that makes better contact with the wheel. They aren't for incorrect lug patterns though. They're also pretty expensive, probably use the extra cash to get the correct lug pattern.
Quick Reply: 5X115 vs 5X114.3
