GXP - 5.3 "Tune-Up"
Old 03-14-2011, 01:34 PM
Chevyman001's Avatar
Default GXP - 5.3 "Tune-Up"
I am getting ready to pull my 05 GXP out of storeage. Before I start doing modifications to her I want to do a complete tune up on it. Its got about 70k miles and figured Id change all the fluids now, plugs, wires, & coilpacks.
Just was curious what is the best way to remove the rear spark plugs on this? Is there room between the firewall & back of the engine? I havent personally looked yet, but I know its a tight fit...Any suggestions on this?
What spark plugs would you recommend to run? What wires would you recommend?
Are MSD Wires & Coilpacks worth the money??
Old 03-14-2011, 04:56 PM
blakss's Avatar
I would say run truck coils and msd wires you can pick thoses wires and plugs from nasty performance
Old 03-14-2011, 05:06 PM
Nick_Nasty's_GXP's Avatar
Aren't our stock plugs and wires great? I head that it's pointless to change....
Old 03-14-2011, 05:21 PM
2005gxp's Avatar
keep your stock coils, go to msd wires.
Old 03-14-2011, 06:08 PM
TheMonteMan's Avatar
not to thread jack but what color are the factory wires supposed to be?
Old 03-14-2011, 06:29 PM
Brian396's Avatar
At lest it on topic I seen what you did to the bumper chip thread.
Old 03-14-2011, 06:56 PM
cacicgtp7's Avatar
The coils, plugs, AND wires are NOT worth changing in these cars. GM didn't skimp out on the ignition system, and there aren't any gains to be hand doing so. Put your money elsewhere. Just my 2 cents, but many others can back up that logic as well.
Unless your plugs are messed up, there's not any point in changing out the plugs either as they're iridium and "supposed" to last till 100K, granted many don't, but if it isn't broke, then don't fix it. Unless for some reason you just LOVE copper plugs.
Like I said earlier, factory wires are good, and the only reason to change them is if you have one that's bad, or feel like making your engine bay "pretty" and getting colored ones.
/usual response.
Old 03-14-2011, 07:33 PM
2007SSImpala's Avatar
/usual response.
I have had my same plugs and wires on for 224,000 miles.
Old 03-14-2011, 07:55 PM
Kazmaniac's Avatar
This is good information.
Old 03-14-2011, 08:06 PM
94ss06gxp's Avatar
x2???
also i would do maybe a trans fluid change., oil change maybe if your due?
Old 03-15-2011, 08:01 AM
lol. that was his ****** fault!!! seriously though what color are the factory wires cause mine are red?
Old 03-15-2011, 11:32 AM
1BAD06MCSS's Avatar
I changed my plugs 2 months ago and it was well worth the money (next is plug wires and tranny fluid change). My car has 94k on it and was in dire need of a tune up. I went with NGK tr55 plugs from Autozone. Changed them myself and it took about 3 hours to do. The front 4 are real easy to change, it's the back 4 that is going to take you a looooong time! I did mine by crawling on top of the motor and by going underneath. If you have access to a lift, then this will help speed it up. The dealership wanted $115 in labor to do it. From a performance perspective, I noticed a difference right away and while it was not dramatic, it was noticeable. The motor just felt stronger.
Old 03-15-2011, 03:03 PM
LS1>girlfriend's Avatar
GXP plug wires are red.
Old 03-16-2011, 07:46 AM
hmm anyone else have a mc/impss that can confirm that theyre all red?
Old 03-16-2011, 07:58 AM
Yes. They are all red.
Old 03-16-2011, 09:24 AM
SidewaysV8's Avatar
Old 03-16-2011, 10:12 PM
MyBadZ's Avatar
Seems like i did them on my 06 GXP and they weren't that bad. yea the backs were the hardest but with a swivel i got them done.
I am pretty sure my wires are red.
Old 03-30-2011, 10:45 AM
Forgot I posted this up.... I think its about time for a tune-up. Im at about 80k and after sitting over winter and running a few tanks of gas through and other stuff it just doesnt seem A1 to me and Ive noticed a bit of a loss in fuel economy.
Going to go with MSD wires. Not sure on plugs yet but will be looking for some Iridium's more than likely. Any suggestion on replacement plugs. Ive ran NGK before and didnt seem too bad.
Also whats the difference between the truck coil packs and ours??
And will be doing trans flush any suggestions on trans fluid/filter for replacement??
Old 03-30-2011, 03:47 PM
LS1Tech Sponsor
06MonteSS's Avatar
don't go with MSD wires!! MSD wires introduce misfires... they're not that good... have seen it many many many many times...
stick with stock AC Delco's (which are very good) or go with the new NGK wires...
better to do it right the first time, then have to try and do 'em again..
NGK iridium for plugs.. . TR5IX for stock replacement... or TR6IX for one temp. range cooler..
no need to change the coil packs..
and don't do a tranny "flush"... flushes are bad bad bad... just have them drop the pan and drain the fluid, replace the filter, refill with dexron tranny fluid, and good to go..
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 03-30-2011, 04:58 PM
rkvette's Avatar
i agree with cacictp/o6montess-posts. my daughters 2006 monte ss had 105,000 miles before we did anything . then did everthing/plugs /wires/ etc. worst except plugs ,coolant bottle was a pain .. all factory stuff again .. why do want to change something thats not broke ! we noticed no differance in perf. or mpg...gm did the homework for us. guys that say differant stuff is better ? how many tens did you pick up at the strip/and dyno numbers to prove it ? our wish for us [ls4] owners would be for trannys to last that long ! our first one went at 40,000 miles just out of warranty .. gm rebuild was $3,500 ,they split bill with us, paid $1750. of course warranty is 100,000 miles on that tranny ...daughter loves her monte ss, and is running great ! rkvette
Quick Reply: GXP - 5.3 "Tune-Up"
