HID's With Quad Bixenon Projectors - LS1TECH
Thread Tools Search this Thread
Old 04-23-2011, 01:59 AM   #1
Default HID's With Quad Bixenon Projectors
I need to do some more dremmel work so the housing can sit back all the way , also need to drill the holes bore BIXE , wires to pass through , also need to do some trimming inside the housing to allow for more rotational adjustment.
Sadden is offline   Reply With Quote
Old 04-23-2011, 02:42 PM   #2
Haulin_Ls4_GxP's Avatar
They look nice but how did you get them to fit. Could you take more pictures of what you had to cut/mod maybe do a write up please sir.
Haulin_Ls4_GxP is offline   Reply With Quote
Old 04-24-2011, 12:38 PM   #3
Well right now the hosuings fit in the car but the projectors dont quite fit the housing.
Your interested in the area behind the headlights or inside the actual headlights themselves?
Old 04-24-2011, 10:25 PM   #4
I want to see what you have to do to get it all to fit right.when you say housing are you talking about the the trim around the projector? Or does the projector itself have a housing it sits in?
Old 04-25-2011, 10:36 PM   #5
To clarify i had to dremmel out the back of the headlights themselves , and then i had to dremmel out the area of the car behind the headlights because the projector s and bulbs etc all stick out behind the headlight further than normal.
Right before i do final assembly ill take some photos of what all i did.
Old 04-26-2011, 12:25 AM   #6
Ok i see what to are saying now. How are you going to seal it up once your done?
Old 04-26-2011, 04:22 PM   #7
Right now im looking for Butyl which is oem on some vehicles its a soft moldable past that will allow multiple openings and closings of the headlights if need be , might end up using silicone though as im having issues finding butyl
Old 04-26-2011, 05:57 PM   #8
no way! stop! no silicone!!! NAPA sells windshield butyl, or search amazon for Nissan Butyl (its the best one)
mike690003 is offline   Reply With Quote
Old 04-26-2011, 07:07 PM   #9
Ill have to try napa thanks.
Old 04-29-2011, 03:29 AM   #10
So grabbed Butyl and some epoxy , did some more work and finnaly took this build for a test drive , the lowbeams need alot of aiming to actually be usefull , the highbeams on the otherhand , lets just say that i can see clearly in the ditch 30 seconds ahead of me at 60 mph...
And by clearly i mean i ran out of road before i ran out of light...
Related Topics
Thread Thread Starter Forum Replies Last Post
92 Camaro turbo lsx build 51k original miles j88l98irocz Forced Induction 16 02-03-2013 11:28 AM
Electronic flashers for LEDs......come on in sjsingle1 Appearance & Detailing 11 09-22-2012 01:56 AM
Artic White 67 Camaro Forged Ls1 Iron Block Turbo Build *UPDATE 4/5/11 X-OVER WELDED* RNation0001 Forced Induction 196 07-14-2012 02:28 PM
1970 Chevelle Conversion using Holley Parts... Road to LS-Fest RNation0001 Conversions & Hybrids 5 09-18-2011 07:48 AM
Pate Swap meet 2011 sjsingle1 Other Special Events 84 05-01-2011 11:40 AM
Tags
2011, 5five, bi, bixenon, d2s, hid, hids, mini, morimoto, optima, projectors, quad, retro, review, xenon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
