differnce between tap shift and auto
Old 04-28-2011, 05:08 PM
WhiteGXP313's Avatar
Default differnce between tap shift and auto
is there even a difference? if your at a dead stop and you floor it are the shift points the same? all tap shift does is let you choose the gear (except 1st is disabled if your going over 40mph)
Old 04-28-2011, 05:23 PM
Battle_Ravage's Avatar
You can run the gears out longer and there's no shift lag.
EDIT: It holds gears in Tap, so no the points aren't the same.
EDIT2: Auto (untuned) shifts at 89 into 3rd, Tap runs to 102 before hitting limiter in 2nd.
Old 04-28-2011, 05:35 PM
ima try this today loll
Old 04-29-2011, 02:35 AM
Sadden's Avatar
My shifts seem to feel firmer in tapshift , maybe its just because im more aware of the shift idk....
Old 04-29-2011, 08:50 AM
D J Real's Avatar
Thats because they are. In TAPshift the computer raises the line pressure of the transmission fluid.
Old 04-29-2011, 10:43 AM
DavidGXP's Avatar
Tapshift is a joke. I wish Pontiac would have give us the option to turn off overdrive and a performance button like the older GP's had
Old 04-30-2011, 01:26 PM
LS4:20's Avatar
Is there a fuel cut-off in 1st at redline? I pushed my 1st a little too hard the other day and when I went to shift (around 5900), the car bogged real hard, then shifted.. Got me killed in my race against a 97 2dr GTP.. Which by the way, should NOT perform as good against us V8'ers ..
Mind you my tranny was around 205 degrees and the car was about 190... Lol.. His was just started on a lukewarm day.. He weighs 160, I weigh 260.. I had a 200lb passenger, he had no passenger.. Not sure about him, but I had a 3/4 a tank in gas.. I SHOULD have lost that, right?
Old 04-30-2011, 02:43 PM
DavidGXP's Avatar
Those Supercharged 3800's are no joke and they perform even better when cold since they don't have air to air coolers.
LS4's average mid to low 14's as do stock GTP's.
Drivers race..
Old 04-30-2011, 03:47 PM
Panther427's Avatar
and if you dont hit the button soon enough it does bog before it shifts
Old 04-30-2011, 05:49 PM
^ Yep. Fuel cutoff is 6100 or 6200. Any time I mentioned missing a shift, that's what I'm talking about.
Quick Reply: differnce between tap shift and auto
