Ls1 truck intake manifold
Hello i have a ls1 truck intake manifold with fuel rails 25317669 injectors and tb will this swap onto my ls4 (08 gp gxp) like the ls1/ls6 intakes do? It looks tall!!! what other modifications would it take to put it on and is it worth it? I have seen some tests where the truck intake manifold was better than the ls1 and compared to the ls6 until higher rpms.
ALL HELP IS APPRECIATED
Thanks Logan
Thanks Logan
but isnt that what Brian396 did was put an TBSS intake on his car?
https://ls1tech.com/forums/ls4-perfo...ke-option.html
If you have a regular truck intake with a 3 bolt TB, then it should bolt on. The alternator bracket would probably need to be modified. The fuel rail is for a return system and won’t work. The dbw 78mm truck TB won’t work either, and you’ll need some sort of TB adapter to run the LS4 TB. Oh and I’m not sure how much hood clearance the other cars have. On the GXP the hood won’t close with the hood insulation on.
