A/C blows colder on passenger side
Recently I just noticed on the dual climate control that the passenger side blows colder air than the drivers side. anyone know what could be the cause???
Did you ever get a resolution to this problem? Mine was doing the same thing. Found that it had a slow leak in the low side ac line due to a hole that was worn into it by the shifter cable.
LS1Tech Sponsor
there was a tsb out years ago, a bcm re-programming update for an issue with the vents not opening up fully or completely switching to the correct position when the **** is turned....
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
