Been awhile but need some help.
Old 06-14-2011, 08:05 PM
StealthV8's Avatar
Default Been awhile but need some help.
Hey guys, sorry i havnt been around lately or for years lol but have been dealing with a lot of personal problems. Anyways heres the car problem, the car has been sitting since december, i started it once last month and today when i went to start it i got a msg on the dic says charging system failure, tc off, abs off, etc. The battery is at 12-14 volts and i changed one of the post connections hoping that was it but with no luck. Any ideas? I'm getting very close to selling this thing even tho its paid off and i love it but ****.
Old 06-14-2011, 08:30 PM
higsy's Avatar
All I can say is any time I get those messages it has always been the battery. I store the car in the winter so I've had to charge it many times. Maybe the voltage is too low when you go to start.
Old 06-14-2011, 08:45 PM
gxp-miller-gxp's Avatar
make sure both terminals are good and extremely tight.if i can be moved with your hand or off even with a good amount of force it isnt tight enough. just keep running and drive around and see if the **** will work itself out
Old 06-14-2011, 08:55 PM
DavidGXP's Avatar
This happens to me everytime I let the car sit for more the 3 weeks. I have learned to disconnect the battery when parked for extended periods of time. I'll even pull the battery and place it on wood.
Old 06-15-2011, 01:32 AM
StealthV8's Avatar
I disconnect the battery all the time when it sits but maybe its not holding the charge????? I'll have it hooked up to the charger check the voltage usually 13v then i hook it up to the car and it drops within seconds to 10-11v.
Old 06-15-2011, 09:40 AM
MidLifeCrisis's Avatar
your battery has a dead cell. you need to replace it.
Old 06-15-2011, 11:51 AM
Super LaX's Avatar
Yup. Had it happen to a 2 yr old Delco. Replaced under warranty.
Old 06-15-2011, 12:53 PM
1BAD06MCSS's Avatar
I just had my alternator replaced and it had the battery charging system failure code in my DIC. Warranty replaced it for a $100 deductible.
Old 06-15-2011, 05:17 PM
Panther427's Avatar
battery could be leaking too
