Belt Tensioner Broke Off!
Old 07-18-2011, 01:38 PM
gixper's Avatar
Default Belt Tensioner Broke Off!
So my belt tensioner broke off, tore up my belt, and damaged my CV Boot in the process. Dealership says $1400+ to fix How difficult of a task is this? I'm mechanically inclined. Any special tools required? Any help would be great. Thanks!
Old 07-18-2011, 01:48 PM
DavidGXP's Avatar
1400 kiss my ***. You can do it for less then 300.00.
Not hard at all
Old 07-18-2011, 03:39 PM
Anniversary "Z"'s Avatar
Call up your local parts store. Everything you need is fairly cheap compared to the $1400 BS quote you got
Last edited by Anniversary "Z"; 07-18-2011 at 05:02 PM. Reason: Posted some bad info
Old 07-18-2011, 03:48 PM
neilownz's Avatar
Wrong parts.
Old 07-18-2011, 04:30 PM
LS1Tech Sponsor
06MonteSS's Avatar
yeah.. can't replace just the cv joint/boot on our cars... heheh... have to replace the whole axle assembly...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 07-18-2011, 04:39 PM
DavidGXP's Avatar
Dooh!
Old 07-18-2011, 04:40 PM
DavidGXP's Avatar
I wonder why some peoples cars are doing this?
Old 07-18-2011, 04:44 PM
1CL3ANSUP3RSPORT's Avatar
Take off passenger side tire remove wheel well.remove axles for more room and since you have to replace it anyways....
Old 07-18-2011, 05:03 PM
Originally Posted by neilownz
Wrong parts.
thanks for double checking that can't trust the EBay cross reference thing at all.
Fixed my post to make sure nobody screwed themselves!!
Old 07-19-2011, 01:11 PM
gixper's Avatar
That makes sense...that's why I can't find just the boot!
Didn't think about that...but remove the wheel well? I'll have to take a look when I get off. Thanks for the tips guys!
Right now I'm forced to drive my Skylark. Dirty, smudged up primer, with rust poking through and no A/C in 105 degrees!
Old 07-21-2011, 07:54 PM
fieroguru's Avatar
I have a tensioner assembly (minus the pulley) that was removed from an 18K mile 2007 LS4 is you are looking for a used part... $45 shipped.
The following users liked this post:
Chevrolet102616 (04-29-2023)
Old 07-22-2011, 08:07 AM
gixper's Avatar
Yes! Thank you! I will PM you.
Old 07-10-2017, 10:44 PM
Super Babies's Avatar
Default ***please help*****
nobody seems to be able to help me!!! I have a 2006 chevy impala SS with the 5.3 liter v8. I have the pulley to this part in your picture that needs to be replaced and I have no idea how to do it!!!!! I have at this point taken off the tensioner spring(doesn't appear to be compromised at all) took two 15 mm bolts to get it off this was of course after I had released the tension by taken the shredded belt off that led me to the damaged pulley in the first place. Now that I have the spring off I'm still just trying to figure out how to replace the pulley. Any info will help. Thanks in advance
Old 07-13-2017, 10:35 PM
fieroguru's Avatar
The pulley bolts onto the tension bracket with a torx bit bolt. With the proper bit and a 3/8" ratchet wrench, the bolt holding the pulley just backs out, then take the pulley to a parts store and have them match it up.
Old 07-14-2017, 09:54 PM
GPGXP's Avatar
What's the best way to get a stuck pulley off then tensioner besides cutting it?
Old 07-16-2017, 02:09 AM
superglide9375's Avatar
vise?
Old 07-16-2017, 02:16 AM
lot easier on car with tension but see no reason why trusty vise wouldn't work and very cool of fieroguru to pull that part, does anyone have ls2 manifold they want to get rid of ill throw my ls1 for the the trade plus cash on my part, good working order got from guy on site talked to spawne 32 today got an audi he is way gone already tinkering with it but still tuning he does my car and its a rocket can have throttle body too but not injectors this is prolly wrong forum but i forgot rules 410-474-9903 thanks
Old 07-16-2017, 09:41 AM
fieroguru's Avatar
Unthread the bolt holding the pulley to the tensioner bracket. If you strip the torx threads, then put a 3/8" or 1/2" nut over the torx bolt head, fill the center of the nut with weld, wait a couple of minutes after the nut stops being red, and use the nut to unthread the torx bolt.
Once the torx bolt in the center of the pulley is removed, the pulley should slide off the boss that it is resting on. If not a little penetrating oil, persuasion with a pry bar, or a pulley puller should help remove it - all the ones I have taken apart the pulley came right off once the bolt was out.
Old 07-25-2017, 11:11 AM
transverselife's Avatar
Yeah sorry that happened. Mine did too... and when the belt snapped it took a 3rd off my radiator. I get why the dealer charges what they do... its a rough job. Get a 6" hose clamp to secure the spring when you install to make the belt fitment easier. That hose clamp will allow you to keep the spring compressed without special tools and a 3rd arm. Works great when you need to do the belt or other accessories on the car as it makes belt movement easy. Just secure the belt with some painters' tape to make sure you don't loose your orientation around the pulleys.
Cheers.
Old 07-25-2017, 11:15 AM
Can I ask why you aren't just getting the whole belt tensioner as one assembly? When mine failed... I had to. It broke in half. I would suggest that... as they are prone to failure and you DO NOT want to go thru this again or loose your perfectly good radiator like I did.
Quick Reply: Belt Tensioner Broke Off!
