MAF Sensor
Old 07-18-2011, 06:54 PM
TML529's Avatar
Default MAF Sensor
Anyone had any experience with Jets' MAF Sensor and is it worth the price of admission?
Old 07-18-2011, 06:59 PM
Pauls325's Avatar
yes do not do it. i got one it makes the car run like crap the MAF sensor screen is really important for it to make accurate readings as well as the airfoil shape that it is attached to. this was a year or two back but i put it in drove it so the comp could get used to it and sent it back right away.
Old 07-18-2011, 07:05 PM
TML529's Avatar
any thoughts/info on the Air aid TB spacer?
Old 07-18-2011, 07:11 PM
94ss06gxp's Avatar
have heard bad things about that also.
Old 07-18-2011, 07:58 PM
xxtheshockerxx's Avatar
i am curious to hear what that is. i just put one on my car recently
Old 07-18-2011, 08:05 PM
TML529's Avatar
What are your reviews thus far?
Old 07-18-2011, 08:53 PM
maybe a little throttle response. cant notice a power gain. and it whistles. i dont mind the whistle it makes it sound like my old intake on my 03 monte. i got it for cheap used so i figured it was worth a try
Old 07-18-2011, 09:18 PM
LS1 Racing's Avatar
TBS is junk, as is anything made by JET.
Old 07-18-2011, 09:31 PM
wesdean78's Avatar
I had a JET MAF but took it out a while ago. I noticed an improvement upon going back to a stock MAF from the JET.
Wes
Old 07-19-2011, 09:21 AM
LS1Tech Sponsor
06MonteSS's Avatar
do not use an aftermarket MAF sensor! they fool the ecm into thinking the engine is running leaner than it really is... bad bad bad... and if/when you go to tune it, it's a PITA to get the fueling correct because of it...
the stock MAF is good for 550-600+ hp anyway... so no need to change it...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 07-19-2011, 06:30 PM
07MCSS's Avatar
What he said. I'm using my stock maf boosted with no issues some room to grow.
Old 07-20-2011, 06:25 AM
TML529's Avatar
Thanks for the info fellas!!!!!
Quick Reply: MAF Sensor
