Clean Engine Bay
Clean Engine Bay
What and or how are you guys using to clean your engine bays & make them look so pristine? I am scared to death to hose it down because of all the electronics. So can anyone give up some secrets?.....Thanks in advance.
i promise you it will be fine housing it down. jeeps and just about all cars can go completely under water if they have a snorkel lol. simple green is good, and armor-all for plastic is great for all the plastic parts. and just about any degreaser is great as well
I use Adams all purpose cleaner and dress it with Adams in and out spray and svrt....you don't wanna use a lot of pressure when u hose it off and don't soak the **** out of it and you will be fine....I would cover open cone intakes as well....if u look at my detailing thread on here you can see some nice before and afters
i use a Hotsy pressure washer on engines at my shop. just soak the engine in degreaser and rinse. it is pretty hard to mess modern cars up. try not to soak coils ecu all that stuff
LS1Tech Sponsor
don't use simple green... it will screw up/eat at your paint if you get it on it...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
At the detailing shop I worked at we used a degreaser, then power washed it off, then used an air house to dry, and drenched it in silicon.
Results like this
But its been awhile so its gotten a little dusty
Results like this
i never had any luck with washing my motor, check engine came on in all my cars when i cleaned them. i take mine to a professional, my current camaro is fine, i do it twice a summer
before
after
before
after
before
after
before
after
you should bring it to me...i have a hunch i wouldnt charge as much
Their is still dirt residue on the engines, camaro has it towards the back for one, then they still have crap build up on the grand prix washer fluid container that comes off pretty easily.
But it does look really good, how do you do it?
Try 2 use pressure washer instead of a water hose....less water flowing with a pressure washer, I'm sure nothing will happen but just w be on the safe side..all I use is purple degreaser then just any foam tire wet stuff!! Had this motor like this for 3 weeks n I live n dirt roads ..
I'm saying this cause for over 5yrs I had a pressure washer n never had a problem but like a Mon ago some stupid **** took my ****!! So I use the water hoes in my car was smoking for 2 days & running like ****...
