PCV valve?
Old 08-10-2011, 09:00 PM
Housor's Avatar
Default PCV valve?
So I was changing my spark plugs the other day and came across what I believe to be my PCV? not positive but it broke off as soon as i touched it after close inspection I realized that there was adhesive wrapped around the broken ends. For time sake we re-glued it, now the engine has a strange almost jitter at idle seems to run ok under load. After listening closely with the engine running I do believe to hear a vacuum leak. the PCV piece dose appear to come out of the plenum but we did not want to start reefing on in fear of breaking the intake my question is dose this piece come out? and is it threaded or dose it twist out etc?
Pics
Thanks!
Old 08-10-2011, 09:10 PM
Andrew91PGT's Avatar
Yes that is what runs to the rear valve cover for the Pcv system. It is molded/epoxied to the intake from the factory. Get some good 2 part epoxy and fix it. It's not supposed to come off. Ask me how I know
Old 08-10-2011, 09:45 PM
Housor's Avatar
Default -
i believe we used Q bond to glue it first off all i have at my disposal is
jb weld? think that's good enough? i was thinking of going out before i go to bed and doing a good generous bead around as smooth as possible to hopefully seal the thing as good as i can
Old 08-10-2011, 10:04 PM
racingcameron66's Avatar
This. It's just a vac port, PCV valve is in the rear VC.
-Alabamaguy
Old 09-06-2011, 06:48 PM
Ghostintheshell's Avatar
Epoxy? Wow. No plug and play?
Old 12-29-2015, 05:58 PM
spy2520's Avatar
Anybody happen to know the part number or where to find the hose that attaches here?
Old 12-29-2015, 08:09 PM
Moderator
91parkave's Avatar
3/8th hose slips right over it the nipple fyi
Old 12-29-2015, 09:37 PM
spawne32's Avatar
discontinued from GM, replace with regular vacuum hose.
Quick Reply: PCV valve?
