LS6 spring shift points
Old 08-13-2011, 10:26 PM
redlightrampage's Avatar
Default LS6 spring shift points
Swapping LS6 yellow springs into the car this week along with comp 1.85 roller rockers, keeping pushrods stock for now. Wondering for those guys who run these springs where you move your shift points to after install? , or where can I move them to safely? I've searched around for a previous thread but didn't have any luck.
Old 08-14-2011, 12:21 AM
DavidGXP's Avatar
6200. Redline 6500.
The 5.7 LS6 Zo6 had light weight valves so they could rev a little higher. I would shift 6100-6200 with 1.85's and move the fuel cut off to 6300.
Your still using heavy DOD lifters so don't rev too high!
Old 08-14-2011, 05:47 PM
Hmm yeah I seen the 6200 number somewhere, what MPH does line up with well for 1-2, 2-3?
Old 08-16-2011, 01:46 AM
vroom_vroom's Avatar
so the fact that i have my rev limiter set to 6500 should worry some of you
Old 08-16-2011, 10:35 PM
ls4door's Avatar
It looks like my car shifts at about 6k? Is it 6 or maybe 5900? Just wondering.
Old 08-16-2011, 11:27 PM
i believe fuel cut off for stock is 6000
Old 08-17-2011, 06:57 AM
94ss06gxp's Avatar
I remember last year at the Woodward Dream Cruise I met up with nmp on here and he was shifting at like 7K in his GXP, it was insane lol. But to hear a GXP lope like that was sick.
Old 08-17-2011, 02:42 PM
Sittingmongoose's Avatar
i would shift at 6200 and have fuel cut at 6400. The problem is though, why shift that high? you wont be making power past 6k.
My shift point is 7k but i have my engine completely built and also have a cam that makes power up there. Even with that, i stop making power at like 6500k.
Old 08-17-2011, 05:02 PM
I'm having the dyno operator do a 1st/2nd gear pull after my header/rr tune changes then I'm going to adjust shift points accordingly. Probably do some repeated timed pulls under as similar of conditions as possible to see how numbers pan out.
Old 08-17-2011, 05:11 PM
the reasoning i had behind mine was before i had my trans rebuilt it had a little bit of a slip between gears and would hit the limiter
Quick Reply: LS6 spring shift points
