Plastidip questions
Plastidip questions
Have any impala owners done it to the front grill? Did you take them off or leave them on? And if you took them off how the hell did you get the bottom one off?
Location: Origionally-Winnipeg Manitoba, Currently-Fort McMurray Alberta
once you get that splash guard out you will be able to get at the clips in the back of the grille.
now the easy way to do this is to take out the whole grille, you will notice the grille comes apart in two pieces, theres the black mesh inside and the chrome trim part. Take those apart and put the black mesh back onto the car.
when you re install the splash guard there will be two smaller splash guards inside the fog light areas, I left them out till I got the guard fully installed, then put the smaller fog light splash guards back in through the fog light port on the front.
once you have your chrome trim painted or dipped, you can just clip it back onto the mesh part thats on the car.
This is a pic of it being taken apart. its a bit of work but looks good in the end.
I ended up having to pry all the clips apart from the back to get it out..
oh wait, I see what your saying, so instead of taking the whole thing out you just took out the chrome bit? well that sounds a hell of a lot easier than what i did lol
I'm going to try this first, i eventually want to do the grills too since mine are also starting to fade but i really want to take care of that chrome, i really hate it.
I just don't really wanna be seen sitting with a q-tip going into every slot on the mesh, lol my neighbors think I'm a nut already, every other day i'm under the car or have it up on jacks.
If I get around to doing it i'll take before and after pics for you guys.
you might be able to get the whole mesh out by popping the chrome trim off as 1CL3ANSUP3RSPORT mentioned, then going after the black mesh bit, i'm pretty sure taking off that trim exposes the clips for the black mesh part.
