LS4 to l92 engine swap
if you bumped the compression up to 11 to 1 on the ls4 with a ls1/6 intake and exhaust you would run faster, let alone what would happen if you put a cam in there you would be above 400hp you would be **** stomping most of whats out there and it would be a LOT less $$$$ in the project, im working on doing something similar
