11/8/11 update gxp
Old 11-08-2011, 11:39 PM
ghetto joe's Avatar
Thumbs up 11/8/11 update gxp
just up date on whats been going on i finally ran my sub woofer amp power wire and have to subs hooked up with factory radio. sounds pretty good if i do say so myself. the headlights sure dim under heavy pounding but the DIC shows steady 14+volts. next project is exhaust, kinda changed our minds on muffler delete and looking into a DMH electric cut out thinking about mounting it right before the Y like several others have. has anyone used one of these cutouts and mounted a collector on the exhaust side to dump the exhaust in a certain direction?
Old 11-09-2011, 11:41 AM
texasGXP08's Avatar
Good Deal! I found that adding a sub to my factory system turned out great as well. You may want to get a capacitor if the lights are dimming too much.
Old 11-09-2011, 08:16 PM
WhiteGXP313's Avatar
As a heads up that space before the y was too small for the cutout I have so I had to move it to the second bend. It's extremely loud
Old 11-10-2011, 02:17 PM
ghetto joe's Avatar
which cutout did you use whitegxp
Old 11-11-2011, 02:32 PM
i have the manual one from summit racing
Old 11-11-2011, 10:37 PM
ghetto joe's Avatar
so you put it in the first bend after the resonator?
Old 11-12-2011, 08:54 AM
https://ls1tech.com/forums/ls4-perfo...ut-cutout.html
