RF Clunk - Over Hard Bumps
Just as the title says; whenever I hit a hard (straight up and down) bump I hear a clunk/pop from the front right. The inner and outer tie rods were loose to I replaced those thinking that was the issue and it was NOT.
Now I am thinking the only thing it could be is the strut/mounts?
Also on a side note, the passenger rear is slightly clunking a little bit here and there. Are strut mounts really common to go out in these cars?
Its an 08 with 70k miles.
I will have to get it on the hoist and check it out again I guess. What is the most common failures of this nature on these cars? I have read the most about sway bar links and strut mounts.
Ok, so a little update. Both inner and outer tie rods were replaced becaues they had place in them, the clunk was still there, the stabilizer link was replaced, the clunk was still there. So I pulled the strut out and the strut mount was all cracked and trashed, so I thought 'finally' I found the problem.
NOPE!
The clunk is still there, the only thing left is the strut itself, right? It is not leaking and doesn't feel like there is any play in it. I don't want to buy a god damn Bilstein Strut and have it not be the problem.
Any advise?
Also for the Bilstein stock replacements do our cars have the HD or Comfort style?
The car is an 08 GXP.
NOPE!
Any advise?
From all the things I have read the comforts are about 5% firmer than stock and the hd's are about 10% to 15% firmer. If you want just a stock replacement go with the conforts
NOPE!
Any advise?
NOPE!
Any advise?
Wonder if they can be rebuilt?
Think about this....not everything or part of these cars is tack welded by a machine.....I also have some clunk tick sometimes when I hit the gas quick or a bump....I think it's a design flaw in the bolts that hold it together somewhere. I like the car car cause my wife says it's sexy. So I keep it.
If you have checked everything else and not found the source of the clunk you might look at replacing the steering gear. The rack bar can create a clunk sound if it hits the piston rod guide (PRG) in hydraulic steering gears when going over bumps. There is supposed to be a plastic bushing on the ID of the PRG but if it is missing (or loose) after xx,xxx miles the pressure applied to the rack bar from the adjusting screw decreases slightly due to wear over time allowing for some slight movement of the rack bar.
I will have to look into this and see how hard it is to check out and replace it if it is a cheap part. I have replaced everything on that side trying to narrow this problem down and have had no luck, I thought that all was left was the strut.
On a side note the rear end of the car is now making a popping noise in parking lots while going slow over unever bumps, I am almost positive that is sway bar links though.
