bad water pump bearings
Old 11-19-2011, 05:54 PM
k9t8m's Avatar
Default bad water pump bearings
Mine are noisy as heck and the pulley is very wobbly. Anyone else had this issue. The car currently only has 81k mi.
I have to take it to the dealership on tues anyway to get the plugs changed, so it looks they will be replacing the water pump as well.
Old 11-19-2011, 07:33 PM
SRTH8R's Avatar
Just did mine at 51k miles. First thought it was a idler pulley squeaking, then the water pump started oozing something out of the bearing.
Old 11-19-2011, 11:30 PM
vroom_vroom's Avatar
its a common problem on the ls4
Old 11-20-2011, 01:55 PM
impala06ss's Avatar
You need to get it changed ASAP. I just changed mine, found the pulley wobbly. Started digging into the housing, see attachment......
Old 11-21-2011, 06:05 PM
k9t8m's Avatar
I dropped it off at the dealership today. Wish me luck.
Old 11-23-2011, 06:47 AM
k9t8m's Avatar
Well I picked it up last night. It really wasnt too bad. I had the water pump done, 2 plugs changed, Lt outer tie rod end, lt wheel bearing, alignment, and multipoint inpection for right around $700.
Now I just need to load my DOD off tune on so I dont have to keep putting plugs in it.
Quick Reply: bad water pump bearings
