GXP Lowering Springs Strut Concern
Old 12-14-2011, 01:15 PM
GXP05's Avatar
Default GXP Lowering Springs Strut Concern
I have a 2005 GXP that just turned 64k miles and my main concern with lowering it is the fact that my struts have 64k miles and I'm not sure if they can handle it or not. Any suggestions???
Old 12-14-2011, 02:54 PM
JessmoMonteSS's Avatar
Only 1 way to find out! You should be OK but if it were me...I would get the struts if you're lowering it, that way it's all nice and fresh and you won't have to worry.
Old 12-14-2011, 03:11 PM
rm08gxp's Avatar
I agree ^^ just keep an eye on the for leakage if you just do the springs.
Old 12-14-2011, 03:17 PM
WhiteGXP313's Avatar
How much are new struts?
Old 12-14-2011, 04:05 PM
Hawkins04's Avatar
For a gxp they are about $850 shipped. If it was me I would just replace the struts since you are already taking them out
Old 12-14-2011, 05:07 PM
Originally Posted by hawkins04
for a gxp they are about $850 shipped.
daaaaam!!
Old 12-14-2011, 06:41 PM
bigalnash's Avatar
Originally Posted by WhiteGXP313
daaaaam!!
but they'll last 100k miles bliestien makes the best
Old 12-15-2011, 05:00 AM
94ss06gxp's Avatar
if it were me i would just use the stocks, 64k isnt much.
Old 12-15-2011, 05:54 AM
bonestockgxp's Avatar
Not to steal the thread but, I jacked the car up the other day and I noticed as I sat it backdown my left rear strut was kinda sticking and studering as it lowered... I did the bounce test.. Good there. Driving around I can hear a thumping sound... Any ideas befor I take it to the shop???
Old 12-15-2011, 06:02 AM
And To add to that.. The inside of my tire is completely bald... As for the rest of the tire it's fine... So camper is way in.. Do I try a shim kit or would that be a result of strut failure??
Old 12-15-2011, 08:37 AM
Hawkins04's Avatar
Get the camber bolt kit that should help with the tire issue I'm not sure about the strut issue your having though
Old 12-16-2011, 11:05 AM
Camper bolt kit?? That pretty much a shim kit
Old 12-16-2011, 11:53 AM
Hawkins04's Avatar
Camber bolt kit check them out online at advance. They are a bolt that you put in place of the bolt in the bottom of your strut so you can adjust the camber of that wheel. you need that bolt because from the factory the only way to adjust without the camber bolt is to slot the holes in the strut for the adjustment
Old 12-16-2011, 01:30 PM
Sint3k's Avatar
I would get new ones
While your doing everything its just better to replace any part that fails or becomes undesirable at 100k and struts is one of them.
Even the springs i would replace with new ones and then cut the coil.
I cut mine on my monte carlo but she was brand new back then. No strut problems so far. I've just replaced the springs n strut on my cadillac 97 eldorado with only 70k miles and they are in horrible shape , i'm sure time had allot to do with it but still.
Also check your knuckle bushings as this can cause poping or grinding sounds.
Quick Reply: GXP Lowering Springs Strut Concern
