E brake question 06 mc - LS1TECH
Thread Tools Search this Thread
Old 12-22-2011, 05:28 PM   #1
Sint3k's Avatar
Default E brake question 06 mc
Hey guys when i replaced my rotors i dont remember what kind of E Brake setup we have. Is it a Rotor of HAT assembly or do we have adjustable disc e brake ? Anyways i've warn em down or stretched the cable one and i need to tighten the cable or adjust the E brake itself
Sint3k is offline   Reply With Quote
Old 12-23-2011, 06:18 PM   #2
I'm sure we have the drum inside the hat of rotor. Just found my e brake not working either. I was able to check my cable is fine its nicely covered underneath. I thought maybe some adjusting. When I have time. Keep us updated.
badata is offline   Reply With Quote
Old 12-30-2011, 07:36 PM   #3
Fixed mine today. Removed rotor and at bottom there is a adjuster wheel. Turning it you will see the pads seperate at the bottom. Just play with it untill they grab good but not draging on drum. Works like new
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
