stroker kit for ls4 - LS1TECH
stroker kit for ls4
Thread Tools Search this Thread
Old 04-07-2012, 10:55 PM   #1
06GPGXP33's Avatar
Default stroker kit for ls4
does anyone if there is a stroker kit for the ls4? just curious to know if one was made? and i also heard the ls2 kits will work for the ls4... let me know
06GPGXP33 is offline   Reply With Quote
Old 04-07-2012, 11:15 PM   #2
The LS2 kits will not work.
We have the small(er) bore block. Our crank is 13mm shorter than a LS crank. Cams and intakes will interchange.
Your closest application would be pistons and rods for a truck 5.3 with a custom stroker crank.
fubar569 is offline   Reply With Quote
Old 04-08-2012, 02:11 AM   #3
Theres been talk about it , depends on how big you wanna go , the crank can easily be machined to our needs.
Sadden is offline   Reply With Quote
Old 04-08-2012, 08:50 AM   #4
Quote:
And also depends on how deep your pockets are.
99slpws6 is offline   Reply With Quote
Old 04-08-2012, 10:16 AM   #5
neilownz's Avatar
Minimal displacement increase for the money. See how much a custom block is if you have cash to burn.
neilownz is offline   Reply With Quote
Old 04-08-2012, 11:00 AM   #6
SSCoop's Avatar
Quote:
I made a post about this when I had my SS and I was told that having these engines bore and stroked were useless unless you were planning on spending massive $$$. Get the 5k turbo kit, a cam, beef up the transmission, some ported heads, the ls6 throttle body, some headers if you don't have them, and a hand held tuner. That would be a lot less than getting this engine bored and stroked
SSCoop is offline   Reply With Quote
Old 07-09-2013, 02:01 AM   #7
Would new sleeves alleviate that issue? If so, how big can one go on these motors? They were available in both Gen III and Gen IV configuration.
Georonimo is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Speedmaster LS 408 4" stroker kit. Ghostx3 Project Comments & Discussion 4 02-17-2016 07:08 PM
408 stroker build Ghostx3 Parts Wanted 0 02-03-2016 09:02 PM
L92 stroker build (need advice please!!!) mt69z28 Generation IV External Engine 8 05-25-2013 02:46 PM
421 stroker? FormulaV8A4 LT1-LT4 Modifications 47 02-15-2013 12:30 PM
Machine shop in Oahu Exidous Western Members 2 05-21-2012 08:42 PM
Tags
2006, 2007, cam, catback, charger, crank, grand, gxp, kit, ls, ls4, prix, rt, stroked, stroker
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
