Annoying squeal only when in reverse - LS1TECH
Thread Tools Search this Thread
Old 05-12-2012, 11:05 AM   #1
Default Annoying squeal only when in reverse
Sounds like front brakes hanging up. Never when driving FWD. Took front brakes apart and could make the noise with the caliper removed but not with the rotor removed. Cleaned inside the hats and found some loose asphalt but still making noise. Id hate to replace a wheel bearing for this issue? Anyone ever had something like this happen to them? No other signs of wheel bearing failure. 08 gxp w/ 43k. suspension and brakes are stock.
rm08gxp is offline   Reply With Quote
Old 05-12-2012, 02:43 PM   #2
it happens to me as well. Still havent found out if its coming from the brakes.
bigboymike68 is offline   Reply With Quote
Old 05-12-2012, 03:35 PM   #3
mine did this for a year. I took the brakes apart and cleaned them 3 times. I had 2 different shops take a quick look. No one could find the problem. One day I was at my buddies shop and we lifted the car 7 feet up and could finally see the issue. When you're looking at the car up on a jack you cant see it but up high i finally found the issue. Look under the brake assembly, near the axle/hub assembly. There is a small metal tag hanging off the hub assembly. I have no idea what it was for but with a little rust it bent just enough to barely touch the rotor. I took a saw and cut it off on both sides, no more noise. Maybe not your problem but i was so happy when I found that!
fyhgxp06 is offline   Reply With Quote
Old 05-12-2012, 03:37 PM   #4
I forgot to mention, mine only did it in reverse at the beginning. Eventually it did it all the time.
Old 05-13-2012, 10:31 AM   #5
Well, I guess myself and bigboymike are going tab hunting! Thanks!
Old 05-13-2012, 11:26 AM   #6
I fixed my problem by doing the front brakes. With the rotors off it still squealed but when I put everything back on it was just fine. I was puzzled as hell but no squeal 2 weeks after the brake job. *knock on wood*
lVloses is offline   Reply With Quote
Old 05-13-2012, 11:27 AM   #7
And I should add I had the same problem, annoying squeal in reverse only coming from the front wheels.
Old 10-11-2014, 05:03 PM   #8
Riggs 74's Avatar
Quote:
Thank YOU Sir, that was exactly my same finding. Reading many post I thought for sure I was in for replacing a front wheel hub, but no, it was a tab-bracket on the lower inside, dragging on the back of the caliper. I pried it away from the caliper and the squealing is gone.
Thanks again for your post.
Terry
Riggs 74 is offline   Reply With Quote
Old 10-05-2015, 06:17 PM   #9
Default squeaking in reverse
i was hearing squeaking while backing up. sometimes as brake pads wear down a small ridge will remain on the outside edge of the pad. i filed and sanded this ridge down. it solved the problem
mascyl104 is offline   Reply With Quote
Old 10-06-2015, 05:58 PM   #10
Mine was the tab on the front as well when it did this, removed the tab on both sides and was all good afterwards.
rottonj is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
gxp brake replacement blkchevyz LS4 Performance 4 03-30-2015 09:39 AM
GXP clunk in rear jldog7 LS4 Performance 27 12-13-2014 04:04 PM
Metallic Squeaking/squealing noise FlyinOn4Wheels Racer's Lounge 25 10-14-2014 08:20 AM
GXP bone jarring ride over small bumps..Struts shot?? need4z LS4 Performance 22 06-17-2014 10:04 PM
front wheel tick noise welldonecj7 Suspension & Brakes 6 05-26-2011 12:52 PM
Tags
2011, avenger, backing, brakes, carlo, firebird, monte, reverse, reverseimpala, squeak, squeaking, squeaks, squeal, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
