Coolant Temp Sensor / Thermostat????? - LS1TECH
Thread Tools Search this Thread
Old 05-16-2012, 09:40 PM   #1
Default Coolant Temp Sensor / Thermostat?????
Got the "Engine Hot No A C" message tonight. Temp gauge doesn't move, stuck on cold. I get heat if I turn it on. Judging by what I've been reading it's probably the temp sensor? I'm a little apprehensive because I've read where people say it was a temporary fix, but ultimately changing the thermostat fixed the problem.
Any help would be greatly appreciated. About to hit 100k miles and this car is pissing me off. Just spent a ton of money getting a stuck lifter fixed (they did them all). Also recently had the water pump replaced.
rquinn19 is offline   Reply With Quote
Old 05-16-2012, 10:58 PM   #2
LS1 Racing's Avatar
Could be the T-stat stuck open or possibly the sensor.
Both are cheap.
LS1 Racing is offline   Reply With Quote
Old 05-17-2012, 07:51 AM   #3
Do both? Start with one? Is one easier than the other to do? I've found multiple write ups on changing the thermostat, nothing on the temp sensor.
Old 05-17-2012, 08:18 AM   #4
Brian396's Avatar
Ha ha yea, do the temp sensor
Brian396 is offline   Reply With Quote
Old 05-17-2012, 02:30 PM   #5
LS1 Racing's Avatar
Yup...Sensor first, and if that doesn't solve it, I'd look at the T-stat.
Old 05-17-2012, 02:34 PM   #6
jasongantt's Avatar
Quote:
yep, sensor first. cause it's most likely the issue. and if you do it when it's cold, and your fast enough, you won't lose much fluid.....
jasongantt is offline   Reply With Quote
Old 05-17-2012, 07:21 PM   #7
ive got a question for you guys since
ive got my car back from the shop ive notice that my temp goes a lil above 220(i believe) but not much higher ive checked the coolant level and its ok im wondering if i have to changed the thermostat yet or what
06chevyimpss is offline   Reply With Quote
Old 05-17-2012, 09:18 PM   #8
Be prepared to catch some coolant if you pull the sensor out first. Wrap the threads in teflon tape before you screw it back in
straitchev is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
07 canyon 5.3 swap/ temp sensor and gauge not reading correctly str8nsty Conversions & Hybrids 2 04-23-2016 06:52 AM
Thermostat removal from stock housing 4boostin Generation III External Engine 5 07-18-2015 07:29 PM
New temp sensor and pigtail, but having temp gauge/drivability issues SteveWs6 General Maintenance & Repairs 9 07-02-2013 12:36 PM
Busted Thermostat? If So, 160 or 180? SupersonicVette New LS1 Owners - Newbie Tech 15 02-10-2011 12:02 PM
Tweak Fan on Temp setting with stock thermostat? TaTommyWS6 PCM Diagnostics & Tuning 4 05-02-2003 05:14 PM
Tags
2012, camaro, coolant, cooling, impala, located, ls4, muffler, performance, replacing, sensor, ss, temperature, thermostat, thermostate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
