Couple of runs at the track
Old 05-28-2012, 10:04 PM
smokin06impala ss's Avatar
Default Couple of runs at the track
Well even though some people dont reply at all to my threads I really dont give a fck . I post up for current or future LS4 owners ...... Here are some pics and vids of last Wednesday track runs. Best time was 13.6 @ 101 Mph
Me vs a LT1
http://www.youtube.com/watch?v=SLudH6Wu35w
Friends Monte Carlo SS
http://www.youtube.com/watch?v=LoJiP7bg1cI
Me vs a 4door silverado( 6.0 cammed , Stalled, Heads , Intake , Tune )
http://www.youtube.com/watch?v=nmLNyICF3AY
Old 05-28-2012, 10:51 PM
Andrew91PGT's Avatar
Do you have any mods? Are those drag radial runs or street tires?
Old 05-28-2012, 10:53 PM
Panther427's Avatar
Very nice. How consistently were you running. Since that's one of the hard things to do with LS4 cars. How are you liking your current front tire choice
Old 05-28-2012, 10:54 PM
They are drag radials and mods are CAI,magnaflow exhaust, LS6 Intake, D.T. Headers ,HP Tuned, TEP 3.29s . With a better burnout , Im sure I can get them to hook a better time.
Old 05-28-2012, 10:58 PM
Better than the Mickey Thompson ETs I had. I ran one 13.6 and two 13.7s @ 101 Mph. Before the 3.29s I was running 13.6s but in cold weather @ 103 Mph.
Old 05-29-2012, 12:02 AM
MillerMonteSS's Avatar
Do you think that you would get a cooler air charge by removing your driver's side headlight? I have seen people do it before, but I'm not sure how well it would work. Nice runs.
Old 05-29-2012, 12:04 AM
Thanks man, I did actually remove the headlight.
Old 05-29-2012, 02:39 PM
94ss06gxp's Avatar
what were your 60ft's?
Old 05-29-2012, 02:41 PM
2.16-2.19
Old 05-29-2012, 02:45 PM
JessmoMonteSS's Avatar
Nice runs man, get that 60' down and you'll see some good times!
Old 05-29-2012, 07:11 PM
94ss06gxp's Avatar
Originally Posted by smokin06impala ss
2.16-2.19
wow horrible, get them in the 1.7-1.8 area on some sticky tires and good DA and you might see a 12.xx slip.
Old 05-29-2012, 07:19 PM
Nahhh..... I think the closest I will get on good DA would be a 13.3 maybe a 13.2.
Old 05-29-2012, 08:12 PM
baltsk8er69's Avatar
Yeah a 1.8-1.9 would get you around a 13.1-13.2. No 12s on that setup. But great runs. I would think 13.6s would come out of intake exhaust tires and tune. So I think your leaving some on the table. A little practice and you should easily be 13.2.
Old 05-29-2012, 08:20 PM
Yeah i definetlly need practice , plus it was very humid and hot ....
Density Altitude: 2035 feet
Relative Density: 94.18 %
Old 05-29-2012, 11:58 PM
DavidGXP's Avatar
Time for some more valve lift with all of that air flow.
I would either cam it, or install some gold race roller rockers from crane cams.
Even though your 60 ft times are hurting your ET, your ET is impressive! I am a little concerned with your mph though.. I would like to see 105 ish with your set up.
What Rpm are you shifting at and who tuned your car? Something is holding your hp back.
Old 05-30-2012, 01:29 AM
Panther427's Avatar
I'm curious too what kinda rpms are you pulling. At the end of your run. With the different gear ratio are you into third? At 100 mph.
Old 05-30-2012, 06:50 AM
Rocker arms and springs are definetly in the plans .
I was hoping better Mph too but didn't happen .
I'm shifting at 6100rpm on first and second. And as for who tuned it , it was tuned by the trans guy . He changed the gear ratio and shift points since they were at 6500 before . Need to get a really good tune on it for sure .
Old 05-30-2012, 06:54 AM
At the end of the run I has shifted in third gear and Rpm was around @ 4800.
Old 05-30-2012, 11:03 AM
DavidGXP's Avatar
Get your afr and timing tables checked. You have a lot more power
Hidden somewhere.
Thanks for posting your times!
Old 05-30-2012, 11:04 AM
DavidGXP's Avatar
Shifts are fine btw
