Won't start
Old 03-11-2014, 08:15 AM
  #141
Ill_Born_ss's Avatar
Spy, can you try using good booster cables from the neg on batt to the block/trans
Old 03-11-2014, 10:01 AM
  #142
spy2520's Avatar
I'll try that.
Old 03-11-2014, 11:06 AM
  #143
Here is the start circuit. Test with your meter and a single blub test lamp (if you don`t have a 12v test lamp simply wire up a lamp and use it)
- in fig 2 you will have to hold the key in the start to complete/confirm that part of the circuit, check as much as you can.
- notice the current sensor as it is on the + not the - be sure it is secure and the tail is pointing to the pos terminal, also make sure the wires to it are good
Old 03-14-2014, 12:03 PM
  #144
spy2520's Avatar
Purple wire to the starter is good. Does the current sensor actually control anything?
Old 03-14-2014, 08:25 PM
  #145
08 pimpala ss's Avatar
I think there is a youtube video on how to make c4 Explosives you could just man i tried something someone told me to do from the forum and BOOOOOOOMMMMM
Just Saying
Old 03-14-2014, 11:21 PM
  #146
Moderator
91parkave's Avatar
I don't know man at this point after all this maybe its just a bad ecm TCM
Old 03-15-2014, 01:21 PM
  #147
Not a good answer, what about the other wires, wires from the switch to power up computers? Yellow ones having power at the ppl only says the start circuit partially works. When you turn the key other things happen to tell the computers to come to life.
The current sensor does play a big role, that little device carries a big stick. From under charging to over charging to shutting things down by 10% to completely shutting things down or even from ever starting up. It CONTROLS... electric power management. I believe I posted a link earlier.
Old 03-16-2014, 01:30 AM
  #148
heavyft's Avatar
Would the low tire pressure prevent anything?
Old 04-07-2014, 10:29 PM
  #149
spy2520's Avatar
ugh....It was a corroded connector on the engine....Ill_Born_ss, 91parkave, I really appreciate the help you gave. Now that the car is running, I'm ready to drive it into a ****** lake.
Old 04-08-2014, 08:38 AM
  #150
LeadfootDuramax's Avatar
Which connector? Can you tell if something specific happened to cause the corrosion?
Old 04-08-2014, 09:00 AM
  #151
spy2520's Avatar
Unfortunately I dunno, took it to the dealer. They said it had been corroded for a while. Probably on the verge of not working for a long time.
Quick Reply: Won't start
