new track times
Old 09-26-2012, 08:41 PM
baltsk8er69's Avatar
Default new track times
Ok I ran it tonight untuned....the car is tuned just not for the mani swap. So that would still make a difference? I ran a
13.8 at 102.26 with a 2.19 60 ft.
And
13.8 at 101.78 with a 2.16 60 ft.
81 degrees 70% relative humidity wired the times were the same but not the traps. I have ls1 manifold. Hogan catless downpipe. And flowmasters on stock exhaust pipes. Car is tuned but not since ls1 manifold.
Old 09-26-2012, 10:40 PM
smokin06impala ss's Avatar
Nice times man, but once retuned and in cooler weather you will see better times . I'm waiting to upgrade my valve train so I can make a trip to the track and hopefully by then the weather will help as well .
Old 09-27-2012, 11:07 AM
DavidGXP's Avatar
You need a tune, since you have changed the airflow characteristics of the engine. The MAP sensor is reading different pressures at WOT. I bet your AFR is way off, and the engine can use a little more timing.
I went from 245fwhp to 277fwhp after the ls1 intake swap and Magnaflow exhaust kit with a lose #4 injector pigtail.
Most early auto LS1 F-bodys (98-00) were putting down 280-300whp stock, which will be hard for a LS4 with just a intake swap to match.
I think LS4 racing has the highest dynoing LS4 with the least amount of mods. Waiting to see what he puts down with headers.
Old 09-27-2012, 11:21 AM
DavidGXP's Avatar
Remove your mufflers for a few runs!
Takes weight off of the *** end and opens it up
Old 09-27-2012, 08:56 PM
SleeperGXP's Avatar
My only mod is a rebuilt tranny with custom minor shift kit and muffler delete it's cut before the y pipe and my 1/8 mile time was 9.36 @76mph is that pretty good o yeah I also need new plugs and wires bad
Quick Reply: new track times
