Waterless cooling
Waterless cooling
I just watched a video on Jay Leno's garage today about Evan's waterless cooling. Seems like a good idea because there isn't water to corrode the internals. As anyone used this or heard about it, and is it really worth the price? I wouldn't mind switching mine to it, especially when it sits in the winter time.
http://evanscooling.com/
Your cooling system won't rust if you use Distilled water. The minerals cause rust and corrosion. Never ever.... use tap water!
Evans coolant is supposed to be some real good stuff, and might be worth a few hp. It is expessive though, and requires a complete flush.
CAI, MSP, TBS, Custom 3'' Exhaust, Hogan Downpipe, Res Del, 3'' Cutout, Fitch Fuel Cataylist, Ported LS6 IM, Ported tb, ported/milled (11:1 comp) heads, Headers, 1.8 yella terra roller rockers, 45lb injectors, Comp springs, Comp pushrods, Thrasher shift kit, HP Tuned, 8300K Hid Kit, Alum Tranny pan, 3.29 gears, 180 thermo, Truck coils, MPD hood, EBC brakes, Rear heightening springs, Michelin PS2's, Don rome stb's, Evans npg+, Tranny Cooler, Poly Mounts, UMI trailing arms
Nice sig.. Every single mod, but no cam? Any dyno or track numbers??
