GXP Sway bar sizes?
GXP Sway bar sizes?
I'd like to replace my swaybar bushings with poly pieces, and I'm trying to figure out what sizes to order. I don't have a dial indicator; best I was able to come up with was using an adjustable wrench and a tape measure.
Rear looks to be slightly under 3/4" (maybe 18mm?), and the front looks to be slightly over that (20mm?).
Does that seem right? I haven't found any solid info on the Google machine, but I saw some mention in some old threads on other boards about 33-34mm bars being stock on the GXPs, and that most certainly isn't the case with mine unless I've got some wrong bar swapped in on this thing.
Front bar connects to the strut and not the LCA. Also thought I'd read in some threads on other forums that the GXP's had LCA-mounted swaybars and not the strut mounted bars?
