Tell me about the Cat conveter law? Mine is going.
Just had a bunch of work done on the car.. just got my inspection sticker and yesterday the check engine light came on..went to the parts store and they plugged into the computer.
Cat bank 1 failed and cat bank 2 failed. So now what. Car has 71K I am the 2nd owner.
Basically it's illegal to not have a cat if your vehicle came equipped with one unless it's an offload vehicle. However it depends on how your state's emission laws are set up. My state doesn't do any checks. If yours does check you can tune out the codes, run a O2 simulator, or run a fake cat (I'm running one, very convincing from the outside).
Moderator
FIRST the guy at the parts store is a .......
NOW our cars do not have a CAT FAILED PID, and THEY DO NOT HAVE a BANK 2.
We do have a Bank 1 sensor 1 and a Bank 1 sensor 2 for the O2sensors and we do have a BANK 1 CAT efficency above threshold and a BANK 1 CAT efficency below threshold.
You need the exact codes and post them.
Also what work did they do!
It could be as simple as the MAF sensor is not connected properly or a vacum hose left off.
Just had the O2 sensors replaced on the car back in October, also the evap canister was replaced in Nov. in Dec had the trans fixed. had the other work is was inside the car. they replaced the controls for the heat/AC control box.
I just did take the airbox out of the car for some cleaning last week. Did not take the MAF off though but I can recheck that.
The only thing I notice is the car is a little louder. This whole exhaust system was junk. The resonator was rusting through so I put in a pipe and my cutout that I had for a while. and also my mufflers were gone so I replaced them too with dynomax ones. But it does sound louder again.. But thanks again will. Get the codes and get back to you soon.
