DOD removal what oil pump
Hi all I've picked up a oil pump from a LSA engine to replace the pump on my ls4 due to removing the DOD. I've done this because people have said the pump will starve the bottom end without the dod system. But now I've read a few more Internet pages and peoe are using ls4 pumps on non dod engines, have I made a wrong move.
Cheers
Cheers
You know back in the LSA days they said if you are modding to put a high volume pump in or else.
So today you have an engine that comes from the factory with a high volume pump and they are telling you to go to a standard pump.
Then the pans had a 5 quart sump
Now we have a 6 quart sump
They did not have an upper end pressure relief valve
We have a 65psi separate pressure relief valve which dumps directly into the sump
They did not have all the windage trays
We have special windage trays
We have superior drain back built in due to the DOD/AFM design
I left my DoD cam and DoD pump in place when I deleted the rest of my DoD system. I now have a new engine because of it. If I were you I would get rid of the pump and put on this:
http://store.katechengines.com/mobil...l-pump-p5.aspx
I used the LS4 pump without any problems. It flows 30% more oil then the std volume oil pumps.LS1,LS2,LS6, etc..
When I installed my new engine, I went with the LS6 oil pump 12586665. HV pumps costs HP and heat the oil up. Keep in mind that the VLOM holds about a quart of oil, so if you ditch it, only put in 5-5 1/2 qts of oil, in order to prevent the oil from foaming.
Use the the LS4 style "red" O-ring 12584922 with the LS6 oil pump. You always match the O-ring to the pick up. The Oil pump pick bore dia is the same in all pumps.
BLUE SEAL
Specifics:
* Oil Pick-Up Tube O-Ring ea.
* Chevy/GMC Pick-Up (1999-2000 LS V8) 1st design
* F-Body (1998-2002)
* Cadillac CTS-V (2004-2007)
* Corvette (1997-2008)
* Thickness = 3.55mm (0.140")
ID = 23.60mm (0.930")
GM Oil Pick-Up Tube O-Ring (2nd Design)
12584922
RED SEAL
Specifics:
* Chevy/GMC Pick-Up (1999-2000 LS V8 engines with 2nd design pick-up tube)
* Trailblazer (2003-2008 With LS V8 engine)
* Hummer H2 (2003-2008)
* Hummer H3 (2008 With LS V8 engine)
* Chevy/GMC Pick-Up (2001-2008 LS V8 engines)
* W- Body (2006-2008 With LS V8 engine - Impala, Lacrosse, Grand Prix)
* Thickness = 4.20mm (0.165")
ID = 20.69mm (0.815")
BLUE SEAL
Specifics:
12584922
RED SEAL
Specifics:
The actual answer comes down to engine math.
The stock pump will function fine and the new blueprinted pump will possibly outlast it.
You will get people that say do this or else, well if they did everything correct to start with it most likely would last. Examples of this is some would install a cam and not put a proper chain kit( as the stock set up has a known habit of grinding material off itself due to a walking cam) or put a set of 6500 rpm LS7 lifters (which are better than the stock junk, but not by much and they do pump up)( my choice would be: GM kit P/N/88958689 Racing Hydraulic Roller Lifter• Special reduced-mass internal components allow for higher limiting speeds with aggressive camshaft designs• Tested to 8,000 rpm in GM Racing applications) or the improper length pushrods, or put a .550 lift cam and then put 1.8/1 rockers and exceed the valves limits, or even oil restrictive pushrods in as to prevent over oiling (not). Everything has to be considered (cold and hot)
The route I'm going is to turbo the engine and run it as mainly a drag car but it will be used for road going use now and again. I already have a ls2 inlet and We had the thought of running the ls9 cam as its a stock blower cam completely remove the DOD system and run the engine on something like microsquirt. Wanting to try and achieve around 550-600whp, (I know about the gearbox side) so if someone could recommend the lifters,pushrods etc to use that would be great.
Moderator
My drivetrain will be on the test stand until I can get it running, I still have all the DoD stuff in the motor for now. Once I know it will run on the M-squirt then I will swap the LS9 cam, lifters, ect, get that running and tuned. Then I will add the turbo stuff and injectors. Hopefully I will have it figured out soon Im getting real bored with the sbc thats in the car now.
I have everything ready for the swap, the trans controller & paddle shifters is installed and wired, the trans cooler is mounted, the axles are done, shifter mods are done, basiclly everything but a working M-squirt.....
Sounds like we are on the same lines tony I've never got that far into the management yet it was more the engine mechanics at the present then ill looks at the megasquirt side. But it would be helpful if you could tell me how how you get with megasquirt.
Cheers
Cheers
not sure
tonypaul, maybe this will assist:
http://www.lingenfelter.com/mm5/merc...=#.UUpied7D_Z4
I got hopes that EFISolutions will be able to sort it out either with the correct wiring and resistors or within the firmware...
