Went to the track today...
Took my car out for the first time this year and sadly it was super disappointing.
Last year I ran a 13.9 and a consistent 14.0 14.1. Since then I got a new transmission built with 3.29 gears and a tune. My best time today was a 14.2 with a 2.2 60'. I was hooking pretty well a couple of times I roasted the tires off the line and gave up from there haha. But I seen other cars with my same set up run 13.5's consistently, so is there anyway to get my car in that time range? I am just confused why I stayed the same and even lost time going from 2.93's to 3.29's and a tune. any suggestions?
I have a poly mount in the front of the engine, I replaced both the lower mounts when I got the transmission done. The drivers side front has a poly mount and the right one had no aftermarket replacement so I just got a new one
You are wrong. Please go research elsewhere, or I could post the 100 threads that argue this same thing with the majority favoring the statement from Duron. Stickier tires will decrease your ET, however, passes with slight wheel spin tend to trap higher than a pass with a dead hook.
Well yes, in general, the more power a car makes, the quicker it gets there and the faster it is going when it does get there.
However, if you're talking about one car having some wheelspin vs not having some wheelspin, our above statements are correct. Some wheelspin = worse 60' and thus slower ET, but higher trap. Dead hooking (of course depends on RPM.. if you're bogging you'll be hurting your 60' anyways) typically results in a better 60' and ET but lower MPH.
In my Camaro, my best ET was an 11.92@118.01 with a 1.7x 60' ... my best traps were in the 119s with 1.8-1.9 60's and 12.0-12.1 ETs.
If your argument is that a 10 second car is going to trap better than a 12 second car will, I will say that you are right most of the time and that I agree with you.
