replacing pcm and bcm
Old 06-28-2013, 11:11 AM
PurpleHaze9414's Avatar
Default replacing pcm and bcm
So the dealer said my bcm is shooting out high voltage and my pcm has a internal malfunction. ... anyone ever have these happen and do they both need to be programmed or is the dealer bsing me
Old 06-28-2013, 01:00 PM
x11 nut's Avatar
Ask them what codes it's putting out, do you have check engine light on?
Old 06-28-2013, 09:35 PM
Codes are c0550 p0573 c0876
Old 06-29-2013, 07:20 AM
Ill_Born_ss's Avatar
Those codes have been seen before in that combination and they ended up being caused by a improper /faulty battery current sensor. Some of them have burnt a hole in themselves. there is a TSB somewhere, it details that the wrong P/N current sensor was installed on some cars.
Old 06-29-2013, 12:21 PM
Is that the black plug that goes over the negative wire by the batter
Old 07-01-2013, 09:02 PM
roadrash187's Avatar
Purple haze that is the circular sensor on the cable. I have had both of mine replaced. First was the ecm, covered under warranty. The bcm wasn't and ran bout 6/700 installed by the dealer. No check engine lights have ever came on in my car when ever something was wrong with it.
Old 07-03-2013, 08:46 PM
do you know where I can find this tsb
Quick Reply: replacing pcm and bcm
