missfire cyl 6
Old 07-30-2013, 11:44 AM
gagt3100's Avatar
Default missfire cyl 6
I have a miss fire on cyl 6 , only does it when it is at idle , sometimes but not always . I changed plugs a week ago. When it misses it ticks . Any thoughts ? Also which one is cyl 6 ?
http://www.youtube.com/watch?v=YlJQh...ature=youtu.be
Old 07-30-2013, 01:09 PM
baltsk8er69's Avatar
Check the gap and make sure the plug wire is tight. Google ls1 firing order and use the serp belt as your origin point.
Old 07-30-2013, 01:45 PM
Crimson Vette's Avatar
Old 07-30-2013, 03:20 PM
gagt3100's Avatar
Thanks guys !!!!
Old 08-01-2013, 02:26 PM
gagt3100's Avatar
Ok i bought a new wire, and checked the gap, all was good. I am still lost on this, Is there a way to check the coil pack?
Old 08-01-2013, 02:39 PM
Have you scanned it to see which code it is exactly? Is it just saying P0306?
Old 08-01-2013, 03:07 PM
gagt3100's Avatar
no codes, thats the funny thing. Just ran a compression test, its all good was between 125-150
edit: I made a video of the problem is rendering atm, hopefully I can upload it
Old 08-01-2013, 03:11 PM
Check the wires to the coil, look for a cut in wire casing or exposed wire. Check the fuel injector as well.
Old 08-01-2013, 03:20 PM
gagt3100's Avatar
I looked that them all was good, what I did is replaced the spark plug with one of the old ones. Maybe the plug went bad? is that a possibility ?
Old 08-01-2013, 04:26 PM
You can swap cylinder 6s coil with another cylinders coil and see if the misfire moves to that cylinder.
Old 08-01-2013, 04:42 PM
gagt3100's Avatar
ill try that, I just went to the store. Threw 300 code, random missifire. It is missing more now than it did before, the tick is less quieter than before
Old 08-01-2013, 04:59 PM
gagt3100's Avatar
http://www.youtube.com/watch?v=YlJQh...ature=youtu.be here is a little video
Old 08-01-2013, 06:26 PM
gagt3100's Avatar
checked coil, coil is all good
Old 08-01-2013, 07:03 PM
And this all started after the plug change and not before?
Old 08-01-2013, 07:05 PM
gagt3100's Avatar
yeah.... I went a step colder for my nitrous
Old 08-01-2013, 07:20 PM
You say you swapped an old plug in, was it still misfiring with the old plug? Do you have a check engine light on?
Old 08-01-2013, 07:38 PM
gagt3100's Avatar
I did swap in an old plug, it still missfires, CEL only comes on when it gets pretty bad
Old 08-01-2013, 08:03 PM
Moderator
91parkave's Avatar
you need to verify the whole harness that runs to the connector for the coils, sometimes the wire will break int the retaining clip and cause whacky connections. id pull lightly on each wire to make sure.
Old 08-01-2013, 08:51 PM
Just say **** it and run it on 7 cylinders. Still better than a four banger.
Old 08-01-2013, 09:25 PM
gagt3100's Avatar
Bwhahahhaa ! .
here is another video of me swapping the coil packs. I swear I can change these plugs is under 20 minutes haha
Quick Reply: missfire cyl 6
