Stock Steel Valve Spring retainers
I Installed the Yella Terra 1.8 Roller Rockers, Crane Behive Springs and they sent me the wrong spring retainers so I just put the OEM Stock Steel Spring Retainres back on because I had to get the car back on the road - do you think there will be any problem running the OEM Steel ones
Depends on the spring shape. I got a set of just beehive springs and used stock retainers. The were PAC1218's from Brian Tooley racing - if the specs are same, you might be ok. you run it yet ??
x11 nut - thanks for the quick response - I just compared the specs on your PAC Spring and my Crane Spring and they are identical - they felt like they fit really good on the spring - I should be good
