ls1 rockers
Old 08-06-2013, 07:06 PM
severancej's Avatar
Default ls1 rockers
If i bought just rockers and pins from a ls1, would they drop right into my 06 gxp?
Old 08-06-2013, 07:16 PM
LS1 Racing's Avatar
Yes, they would.
Old 08-07-2013, 05:17 AM
severancej's Avatar
Originally Posted by LS1 Racing
Yes, they would.
Are there any performance gains to be had going with them? Along with like a tune, plugs Catless dp, ?
Old 08-07-2013, 05:22 PM
LS1 Racing's Avatar
No, there's no benefit, as the stock LS1 rockers are the same ratio (1.7) as the LS4.
You could get some aftermarket 1.8 or 1.85 rockers and you'd get a noticeable bump in HP. Just be sure to not get the cheap made-in-China units.
Old 08-09-2013, 04:55 AM
fubar569's Avatar
anything else we'd need to run the 1.85's on an otherwise untouched engine? springs/retainers/etc? pushrods?
Old 08-09-2013, 04:10 PM
LS1 Racing's Avatar
You'd need springs. An inexpensive set of GM yellow springs will be just fine. Stock pushrods and retainers will work just fine with this setup.
Old 08-27-2013, 01:13 PM
Mels SS's Avatar
Whats the best rockers to get? And part# if you have them.
Old 08-27-2013, 06:20 PM
baltsk8er69's Avatar
Go for 1.85s ive heard the harland sharps are good.
You will most likely have to pull the oil baffles out of valve covers to clear. Not sure of the part number.
Old 08-27-2013, 08:10 PM
x11 nut's Avatar
Is that the same for the 1.8 ratio rockers as well ??
Thanx
Old 08-27-2013, 09:57 PM
I've heard some 1.8s fit...but I can't confirm.
Quick Reply: ls1 rockers
