tighten gas cap
Old 08-13-2013, 09:25 AM
streetbanned's Avatar
Default tighten gas cap
Anyone know why my car is telling me to tighten gas cap? Just started doing this. The gas cap is tight.....
Old 08-13-2013, 12:03 PM
baltsk8er69's Avatar
Its the evap purge canister going up. Its sensing a evap system leak. Jack the car up take the wheel next to the gas cap off. Remove fender liner you will see a black plastic canister with 2 plastic lines going one way and one going another and a harness. The lines are quick disconnects and I believe one bolt holds it in. The part cost 40 bucks from the dealer. Take 30 minutes tops. Evap canister..not purge solenoid
Old 08-13-2013, 11:57 PM
BackInBlack02's Avatar
Mine started throwing the evap code, I thought it was the gas cap, replaced it with one from Oreily and the code did not go away, took it to dealer, they replaced the gas cap with a AC Delco and code went away. just my .02. Also, to get it tight its at least 4 clicks, I used to only do one.
Old 08-14-2013, 10:36 AM
Thanks guys
Quick Reply: tighten gas cap
