front end issues?
front end issues?
not sure why, but i cant seem to keep front tires on this car, they all wear out like i got a bad alignment... outside wears first.
i've had my car algined a few times this past tire change and it never was really that bad out if any... but they still did the same thing... is this a common problem?
i thought someone posted something about a fix for it but i cant seem to find it.
pressure fine, i keep it around 30... rotation no, i have a gxp.
guess if its not a common problem i'll just go to another shop for an aligment... and have it checked regularly
you could rotate front tires unless they are directional but hat might not have saved the wear you are seeing. im curious if they used GXP specs or not when aligning it.
