zzp lca issues
zzp lca issues
Has anyone had any problems with the sway bar links hitting the cv boots finally figured out why i keep taking out the boots on my axles i adjusted the sway bar mounts all the way back so i hope that solves the problem any input would be nice
On the mounts that 08 redss used when he did everything they have the 2 bolts that mount them to the sub frame and they have a slide adjustment of about a 1in where can i get the shorter endlinks please
Moderator
ohhh. gotcha. same sway bar mounts im using then, as for the heims i forget the size but i ordered ones with male ends instead of the long one zzp sells with the arms.
looks just like that, i had to slice one poly bushing apart and use that for top and bottom though. not enough stud to use two complete sway bar bushings.
