Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Steering & Suspension Guides
- Camaro How to Change Power Steering Fluid<br>Step by step instructions for do-it-yourself repairs.
How or where do you start to flush/change power steering fluid?
1 Post
Is there a drain plug in the rack or do you remove a hose? I can do it all myself just cant find the info if anyone has done this.Is there a DIY? My PS resevoir's fluid is dark..
Thanks
Thanks
Get another person to help you. Remove the return line (small hose) from the reservoir and have it pump into a bucket or something to catch the fluid. Then get ready with a new jug of power steering fluid and have the other person start the car. Just fill the reservoir as it's being drained and as you start to see clean fluid pouring out of the return hose have them shut off the car, attach the hose, and top it off.
1 Post
Thanks... Would it be easier to put an inline connection fitting to lengthen the hose over the fender of the car to do this?
Thanks bud.
BTW your GXP sounds as fast as u can make these cars. Trick flow heads, cam,ported FAST etc. Just what I did with my Z06. lol Ever drag time it or what can you keep up with or should I PM you.
Derek
Thanks bud.
Derek
1 Post
Wait dumb question.. do you mean remove the small hose attached to the back of the PS reservoir with the compression clamp? How do you fill the reservoir as the car is running and the fluid is circulating and pissin outta the hose.. or is there 2 hoses attached to the PSR.. Man I'm like wahh?? Only owned the car for 2 weeks but it seems so Chinese . wish the motor was turned around straight like my ole Z06 was, then things might make sense..lol Isn't the fresh fluid going to **** out the rear of the reservoir where i removed the small hose? What am I missing here? Or is there something I'm not getting here.. my mind is a mess lately with blanks. lol
Thanks man
Derek
Thanks man
Derek
Thanks bud.
Derek
Thanks bud.
Derek
Thanks man
Derek
Thanks man
Derek
1 Post
Gotcha! Thanks. I can see clearly. Went out to the garage and had a better look. Do you know roughly how much the whole system holds? A couple litres/quarts? You meant new 5.0 stangs right? lol jk..
Thanks again
Derek
Thanks again
Derek
