New interior electrical gremlin... sigh..
1 Post
The courtesy lights don't fade out. They stay on.. fronts on headliner and rear seat side ones on headliner while you are driving. They do turn of after 10 minutes when the GXP is shut off so it doesn't drain your battery. The courtesy lights fuse was ok.. Don't know what the hell it could be. Disconnected the battery for a few hours. That did nothing either. Oh yeah old GM quality. Anyone?? Or do I have to go to the stealership... Driving at night with all your interior lights on ... oh sooo friggin nice.
Thanks for any suggestions
Derek
Derek
1 Post
NO one on the whole internet has had this problem with any vehicle. One guy I read had something similar. Says its expensive fix, wiring in the driver door harness...... F'ing great
Dumb question but are these the same lights that come on with the interior switch? Any chance the interior switch is on or possibly bad keeping them on or are these lights separate from interior lights?
Derek
Derek
2007 Pontiac Grand Prix DirectWire 2.0 Vehicle Information
Left Front Door Trigger gray/black (ajar); tan (open) - BCM left of steering column, 52 pin plug (C2), pins 26, 25
Right Front Door Trigger black/white - BCM left of strng column, 52 pin plug (C2), pin 17
Left Rear Door Trigger lt. blue/black - BCM left of strng column, 52 pin plug (C2), pin 7
Right Rear Door Trigger lt. green/black - BCM left of strng column, 52 pin plug (C2), pin 5
Dome Supervision gray/black + BCM left of steering column, 52 pin plug (C1), pin 43
If you want the full sheet i can email it to u
1 Post
Does the dic show any of the doors open? the headlight switch controls the delay of the lights but there should be a gray-black off the bcm i wanna say the white plug under driver dash left of the colum test that wire its the power to the lights from the bcm here is a tech sheet from DEI
Appreciate it bud!
Derek
1 Post
DIC shows everything is shut. the dimmer is for dash lights only impala guy from 4 posts ago thanks. Only GXp people understand. Thanks 91 park ave keep digging too. lol
Thanks guys really!! Car cant be driven at night. have to call dealership tmrw if not fixed today. GRRRRR..
1 Post
Hey the BCM is the Body Control Module right? Where is the bcm location? So look for a white connector under left of dash and a black and white wire going into it??
1 Post
Dont ask... but its fixed!!! Now got a burnt our back seat headliner bulb..does the housing just pop off with a flat screwdriver? Dont wanna break the light housing. Thanks to all for other stuff.
1 Post
I heard the front push button lamps near the rear view mirror are led and are on a circuit board but dont look LED.. so you cant replace them or whats the case?? Where can I get pure white Leds for foot wells , vanity mirror, courtesy lamps rear.. I guess like I said the fronts you cant do right? Oh and do we have a glove box light..If we do, mines burnt out. Oh and trunk light and license plate. That's enough. Not interested in exterior. Annoying I think. Just want the interior basic bulbs. Did it on my Z06.. huge difference. Made it feel newer.
Thanks man,
Derek
Moderator
Thanks man,
Derek
Thanks man,
Derek
Been working great
Front back footwell all replaced with led lighting
www.ls1tech.com/forums/showthread.php?t=1618811
1 Post
I ordered cheapies off of eBay
Been working great
Been working great
D
1 Post
Been working great
Been working great
Thanks and they look sweeeet!!!
1 Post
Which ones do i order. There are ones that come from HongKong? The first vendor is USA. Are they all the same? How many you get? I'm confused which ones to order. These ones will fit all socket accepters in our GXP's??
These ones from HongKong:
http://www.ebay.com/itm/10-X-T10-Whi...-/371055887866
Moderator
pretty easy install, Just take your time, have a jewlers flat head screwdriver. just make sure you before you pop all the lenses back on that you test the interior lamps with the key in the ignition and fully on, I guess the only downfall to the cheapo leds is that they dont dim out like regular bulbs do so they will appear very soft. Nothing to worry about though. heres an updated link, although im sure you can find other bulbs if you want of a diffrent design, i used 194 bulb type
http://www.ebay.com/itm/20-PCS-Super-White-T10-Wedge-5-SMD-5050-LED-Light-bulbs-W5W-2825-158-192-168-194-/251370483066?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a86d92d7a&vxp=mtr
