Had this code/problem for months
Ok so I narrowed down my major problem to 1 definite problem. Ok so my emission 1 fuse keeps blowing... So i found out that the purge solenoid + the 2 o2's are attatched to that fuse. I unplugged all and pluged them in 1 by one and tested the fuse. The fuse did not blow until I tested the rear o2. As soon as I put the fuse in it blows.
I had a previous issue with the rear o2, the wires pinched between the frame and down pipe and cut them
Looked at the wire running to the o2 and it looks good the loom is not damaged at all. Don't know where to go from here
Well you've diagnosed your own problem just because visually you don't see a short does not mean there isn't one .If enabling that o2 pops the fuse then it's shorted maybe even internally
