Tach output?
[QUOTE=Killerb;18294081]Need to find tach output for this nitrous window switch, anyone got nos installed?[/QUOTE
it will vary every injector will have a pink/blk and a different the tach is gonna be the opposite wire just dont!!! use the pink/blk
Well I got it working, I'm running a nitrous outlet progressive controller part(#00-61001). Seems 2006 ecm doesn't really have a tach output so after probing 3-4 wires I found it was the BLUE wire on the front 'radiator side' main valve cover harness connector. Now i can spray in first with mild shot and some delay.
