Transmission finally out
Does anyone have the exact Steps to tune the speedo in the HP Tuner software. Its not as simple as just changing the numbers to 3.29 , the tables do not turn out right and the VSS pulse does not turn out right either. From reviewing Daves post 3.67 can be used and then used to auto caculate the shift tables , Then change the VSS to 101390. and then change the "Final Drive ratio "ratio" back to 1.00, Anyone got any input , thanks
