Transmission finally out
Transmission finally, out being shipped tomorrow! Took about 8 hours I don't think that's bad for my first go, plus had clearance issue with a mount
Copy, paste drop box link for pics
https://www.dropbox.com/sc/6s84x796j...oJoCbcwrmX1Aga
I just take it and drop it off at there dock with the paper work they sent me
My total cost for the transmission including shipping was about 5100 or so.
I removed and will be installing the transmission myself. The removal of the transmission was very easy. It was more difficult changing a Starter or Fuel pump on a 97 Cadillac
The motor is only suspended from those two points? Is it well balanced or does the motor rotate forward at all? It just seems like you're not at the center of the V... But I guess that doesn't mean the center of mass isn't between those two locations.
Also $5100 is insane... Especially since you're doing the removal and install. You getting it built to handle 1000 hp?
Rear seal and oil pan finally done,I used gm gasket/sealant on mine all the way around,I do not want to drop the subframe again cause of some bs gasket
Sorry this is all the pics I took
https://www.dropbox.com/sc/y7fvbdn1n...6N6es_f_exHWia
It took me about 8 hours to get out. I only had a little problem with it not dropping down because i could not get it off the fly wheel but after unclipping the hood latch cable it gave me the quarter inch i needed to get it closer to the firewall to drop it.
The original owner of the 3.11 chain/sprocket set that i purchased from ended up coming up with a 3.29 chain/sprocket which i wanted anyways and he wanted his 3.11 chain set back cause its rare for whatever reason. So once i get it back it'll be 3.29 instead.
So I finally got my transmission from Dave, and now I began putting it in yesterday, took twice add long to put it back in then it took to remove it, all that is left is intake, computer, exhaust cross over and some under trim, wish me luck and hope all goes well after that I'm going to drain the tank, top fluids start her up and then tune it for 3.29 gears,I also replaced the rear seal and oil pan gasket that added to my time
HP tuner / gear ratio / 3.29
Does anyone have the exact Steps to tune the speedo in the HP Tuner software. Its not as simple as just changing the numbers to 3.29 , the tables do not turn out right and the VSS pulse does not turn out right either.
From reviewing Daves post 3.67 can be used and then used to auto caculate the shift tables , Then change the VSS to 101390. and then change the "Final Drive ratio "ratio" back to 1.00,
Anyone got any input , thanks
