dod delete help!!!!
dod delete help!!!!
hey guys so im in the middle of deleting my dod completely and was just wondering about the stock valley cover it has a dod connector in the middle while the dod delete kits valley cover does not so what happens to the dod connector? do u just unplug it and be done with it or is there something more? thanks
Yes you just unplug or disconnect that and plug the opening, if your reusing the ls4 valley cover. If not it isn't required. Then u have to cut and reweld the opsu at a certain degree, for clearance check the sticky for details
what is limp mode on these ls4 cars? ion my old GTP limp mode basically was cut down on power and 2nd gear start im thats all it is on the ls4 cars it will be fine for what im doing like i said earlier im just gonna start it and drive it on a trailer and that will be it until it gets to the tuner
