Trans lines on 2006 GXP
I've just spent the last two hours reading post and articles on the 4t65e transmission in my 2006 GXP. I read one that said the return line is at the top of the radiator and others that said its the bottom line. If I'm reading this right the return line is the one you want to plumb your trans cooler in. So which one is the return line?
you can buy the ready made kits with instructions from triple edge performance, they sell 3 different kinds, one that is inline with the radiator cooler and the others are independent, a little pricey, but it pays in the long run, easy installation, all earls AN fittings and SS hose.
cooler
i got the cooler from triple edge and my temps went down abot 15 degrees -money well spent-also the shift kit is good to do on filter and fluid change,if u call them they will walk u through everything,they made one specificately for ls4 so u cant order wrong one
Moderator
You can do way better for cheaper on the cooler it doesn't have to be from tep to do the same or better job. I'm doing the same as guys who spent almost 300 for a trans cooler with a junkyard oil cooler. Just saying keep youR mind open to other possibilities especially if your budget is tighr
max1
yes that is it-if u are more handy u can get the hayden cooler and lines and ends and make them up yourself save yourself over half probably but I'm not that good at stuff like that so i went with proven and all leg work done for me as i like it lol
