Rocker arm tourqe spec
22 ft lbs
10 Rotate the crankshaft until the number one piston is at TDC (see Section 3 ). With the number one piston is at TDC, tighten the intake valve rocker arms for the Number 1, 3, 4, and 5 cylinders and the exhaust rocker arms for the Number 1, 2, 7, and 8 cylinders. Tighten each of the specified rocker arm bolts to the torque listed in this Chapter’s Specifications .
11 Rotate the crankshaft 360 degrees. Tighten the intake valve rocker arms for the Number 2, 6, 7, and 8 cylinders and the exhaust rocker arms for the Number 3, 4, 5, and 6 cylinders. Tighten each of the rocker arm bolts to the torque listed in this Chapter’s Specifications .
