Transmisson cooler install
Was wondering if I can mount this new cooler upside down where the inlet and outlet were facing up? It would be in a better location if I can I cant find info on if you can or not
yea i think i needed a fan being that my tranny gets kinda warm still even with 2 coolers since i had this stall convertor installed and this one is build good and its 2 inches thick so that should get my temps down really good im also getting a 160 degrees temp sensor that will cut on the fan and cut it off at 145
Moderator
The factory trans cooler needs to be out the picture anyway. Personally I'd go for airlow and surface area over a something that will draw more power from the car.
Long Tru-Cool Max LPD 30,000 Transmission Oil Cooler 4921-1 49211 https://www.amazon.com/dp/B00B0OYI9O..._dQpRvbSJH92WC
i have a derale 18,000 i believe on the car now but the other cooler is a tube and fin and it was the first one i bought being that i didnt know about coolers so im gonna put that plate and fin with the fan in place of the tube and fin to get my temps down
